Threaded View
    This forum looked a bit empty so I've posted this here. Whilst not a 3 axis machine it is technically CNC. I have posted this design elsewhere so apologies if you've already seen it.
    What and why?
    It's a device intended to drive a rotary table, lathe head or any form of indexing device. It's cheap - the electronics running around £30 and (for a small 4-8" table at least) can use some of the appallingly cheap steppers and drivers we see around these days...
    I made it after purchasing a set of division plates for my 6" vertex table, I played with them and then decided they were tedious and error prone. So I designed this.
    Basically the controller connects to a stepper which you've coupled to your rotary table / lathe head / dividing head etc. Then with a couple of button presses it'll divide, move by an angle, move continuously for machining or if you're feeling adventurous you can program complex sequences of moves which can be driven automatically or with operator intervention etc.
    Being a standalone device, it doesn't tie up a computer and is much simpler to use.
    For example to divide a circle into 171 parts - turn on, press [2] (division) enter the number '0171' and press [G]. Each press of left or right will now move the table 1/171 of a circle anticlockwise or clockwise. Backlash compensation is automatically applied.
    The current position in degrees, current division and total number of divisions are all shown on the LCD display.
    Main Features:
    * Stand-alone operation. No computer needed.
    * Jog mode. For easy positioning.
    * Division mode. Divide a circle into any number from 1 to 9999 parts.
    * Degree mode. Move any number of degrees from 0.01 to 359.99 in 0.01 degree steps.
    * Continuous drive. Table is driven continuously CW/CCW at one of the (selectable) 5 speeds.
    * Program mode. Allows complex sequences to be carried out and automated. (10 programs can be stored)
    * Configurable for any worm drive from 1:1 to 9999:1.
    * Five speed settings.
    * Configurable for all common stepper / driver combinations.
    * Five machine profiles.
    * Automatic backlash compensation.
    Attached (should be) Rotary V2.0.zip - unzip this into a folder somewhere and double click on 'Documentation.htm', this file has links to other files including a manual, partslist, circuit diagram etc. Most of it should be self explanatory. Since the device is based around a microcontroller (18F452) I've also included the firmware for it (I notice elsewhere on the forums someone has very kindly offered to program these for free...)
    I've also attached some photos of the completed unit and one of it in use (hooked to a 4" rotary table which is in turn bolted to my lathe head for a spot of gear cutting).
    A number of these have been built by people in my local engineering club and people who've simply 'come by' the plans. There are a number of similar commercial designs, but I reckon this knocks spots off them and for a fraction of the price...
    Hope it's of some use to people here.
Name:	external (538 x 600).jpg
ID:	262   Click image for larger version.
Name:	In use (450 x 600).jpg
    Attached Files Attached Files
  1. Diy 4th axis rotary table using 100mm chuck with minimal backlash
    By kingcreaky in forum Linear & Rotary Motion
    Last Post: 05-09-2013, 01:03 PM
  2. Which chuck to fit 6" rotary table??
    By wiatroda in forum General Discussion
    Last Post: 10-08-2011, 08:47 AM
  3. Mounting a chuck on a Rotary table
    Last Post: 02-09-2010, 07:23 PM
  4. Rotary Table CNCing
    By irving2008 in forum Gantry/Router Machines & Building
    Last Post: 19-02-2010, 11:57 PM
  5. Setting up work on the rotary table
    Last Post: 09-01-2010, 10:27 AM
