    thank you for your contribution I'll start gattering the parts and beguin on the project, I do have one question do, how it will afect the table if i use gear reduction or do i have to use it with a straight shaft and no reduction?
    It depends on what you mean by reduction gear.
    If you simply mean the worm on the table (i.e. in the case of a 6" vertex which is 90:1 reduction) then it's designed for that.
    If you wish to reduce the gearing further by driving the input shaft to the table via a reduction gear then you can do it providing you're not reducing it by too much.
    Basically it's down to the maximum number of steps for a single 360 degree rotation of the table. These can't exceed 65535 steps. So with a half stepping (400 step) motor, and a 90:1 reduction ratio the number of steps per 360 = 400 * 90 = 36,000.
    If you tried to drive this through a 2:1 reducer you'd need a value of 72,000 which is too high.
    Hope this helps
    Steve.
  1. Diy 4th axis rotary table using 100mm chuck with minimal backlash
    By kingcreaky in forum Linear & Rotary Motion
    Last Post: 05-09-2013, 01:03 PM
  2. Which chuck to fit 6" rotary table??
    By wiatroda in forum General Discussion
    Last Post: 10-08-2011, 08:47 AM
  3. Mounting a chuck on a Rotary table
    Last Post: 02-09-2010, 07:23 PM
  4. Rotary Table CNCing
    By irving2008 in forum Gantry/Router Machines & Building
    Last Post: 19-02-2010, 11:57 PM
  5. Setting up work on the rotary table
    Last Post: 09-01-2010, 10:27 AM
