Hi Michel,
If you're using the 'enable' line from the controller then I'd suggest not using it and leave the driver permanently enabled instead.
I used it with my home made driver to put the motor into a low power mode. However lots of drivers simply turn off the motor when this is used.
If you're not using the enable line then the issue is with your driver. Some drivers will turn off if there is no activity after a preset time (most modern one's automatically go into a low power state which is ideal). This behaviour may be programmable so check your documentation.
Hope this helps.
Steve.
Diy 4th axis rotary table using 100mm chuck with minimal backlash
By kingcreaky in forum Linear & Rotary MotionReplies: 3Last Post: 05-09-2013, 01:03 PM -
Which chuck to fit 6" rotary table??
By wiatroda in forum General DiscussionReplies: 19Last Post: 10-08-2011, 08:47 AM -
Mounting a chuck on a Rotary table
By irving2008 in forum Machine DiscussionReplies: 17Last Post: 02-09-2010, 07:23 PM -
Rotary Table CNCing
By irving2008 in forum Gantry/Router Machines & BuildingReplies: 21Last Post: 19-02-2010, 11:57 PM -
Setting up work on the rotary table
By irving2008 in forum Machine DiscussionReplies: 6Last Post: 09-01-2010, 10:27 AM
