Page 2 of 2 FirstFirst 12
    That is basically what it tells you to do in the manual for my UC300ETH.
    The AXBB-E is based on the 300 controller.
    Reading the instructions fo the 300 may have helped.
    Although, it's likely the power supply config change made a difference. Is your 5v supply strong enough for all your devices?.
    Page 18 of the AXBB-E manual indicates:
    We recommend to use a power supply with at least 500mAmps of current capability of the
    power supply. More current may be required if more I/Os are used on the unisolated port
    and on the IDC26 port.
    I selected a power supply that is rated for 1 Amp so I should be good. I don't use any IDC26 extension ports.
    Quote Originally Posted by JohnnyCimino View Post
    1. I was sharing the 5V DC Power Supply with several devices. I installed a dedicated power supply that feeds just the AXBB-E board. I believe the AXBB-E is sensitive to any fluctuation in voltage.
    Not that I know about.? Never had any issues with the 5v side other than it doesn't like 24Vdc...
    2. I updated the configuration as follows (please note that on my system I have the AXXBB-E board connected via a cross-over cable directly to my notebook's ethernet card): My ethernet port IP address was changed from a dynamically set IP to a static IP. [/QUOTE]
    Don't understand why you had this issue because every AXBB-E controller we fit talks directly to the PC using a cross-over cable and is set up using a static IP10,10,10,10 mask 255,255,255,0 and we fit lots of them all with this exact setup, never had to use the utility.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Fair enough.
    I went for a 3A for my 300 type because I have 2 Ucbb's powered off IDC26, an 8 channel relay board, 8 channel opto module (5v in-24 out) for servo drive switches, and then there's the stepper driver PD & En connections.
    It all adds up.
    So you just have the AXBB-E alone on the 5v now then?.
    Now you've got it going.... Enjoy ��
  5. #15
    Neale's Avatar
    Lives in Plymouth, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Must admit that I was confused about the device and PC addresses at first when I fitted my UC300ETH. I set the addresses the wrong way round as well. And that's after a working life in IT and a lot in IP networking! I think that the manual is a little bit ambiguous and as long as you read it the right way - or have done it once and see what they mean! - it's OK. Anyway, good that it's working, and don't feel bad about getting it wrong. Now, where's the red face icon when you need it?
  1. Help needed to connect my VFD to the AXBB controller
    By CharlieRam in forum Spindles & Drive Motors
    Last Post: 23-09-2020, 12:10 PM
  2. Replies: 18
    Last Post: 31-01-2020, 11:58 PM
  3. Any USB/Ethernet controller suggestions?
    By jtar40 in forum Motor Drivers & Controllers
    Last Post: 15-05-2019, 07:58 PM
  4. USB/Ethernet controller for Mach3/4 advice
    By paulus.v in forum Control Hardware & Systems
    Last Post: 17-02-2015, 09:37 PM
  5. CNC controller with serial (RS232) communication
    By rnr107 in forum Motor Drivers & Controllers
    Last Post: 28-02-2012, 09:49 PM
