    Hi all, Looking for links for suppliers in the UK, I need flexible 4 core double shielded cable for spindle, stepper drives and motors. I would like to use a orange, green or blue coloured cable, something different from grey or black. Any help would be much appreciated
    Quote Originally Posted by paulh72 View Post
    IGUS uk
    https://www.igus.co.uk/chainflex/unharnessed-cable
  3. The Following User Says Thank You to dazp1976 For This Useful Post:
    Thanks mate, I'm totally new to this, I've had a look but there's loads, you wouldn't happen to know what 4 core shield or double shield would be best for my application. I seen this stuff but way expensive from USA
    https://www.ebay.co.uk/itm/133891673...kAAOSw-K9hVMMF
  5. #4
    Lives in Marple Stockport, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    4 core CY 1mm cable will be fine.
  7. #5
    Coloured cables will be expensive and not easy to find in UK, plus they all do the same job so save your money and spend it in areas which will make the machine better.
    You don't give any details so difficult to recommend sizes but in general, you'll use 0.5mm/2 for signal wires in the control box, 0.75mm/2 for Limits, motors, etc, and between 1mm/2 and 1.5mm/2 for the spindle.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  9. #6
    Oh. I'm setting up for using cat7 solid core shielded ethernet for limits.
    Think I'll have to do a little trial to check it doesn't burn up first before attaching to machine then.
    I've used 0.5mm for control box (RS components, grey) and 1mm for steppers.
    I think my servo is 1.5mm.
    And yes. The UK is total crap or overpriced for supplies.
  10. #7
    Quote Originally Posted by dazp1976 View Post
    It won't burn up but it will fail at some point due to vibrations, not a good idea to use a solid core cable on any machine tool even if it's not moving there will be vibrations that over time will cause it to fracture the cable.
  11. #8
    It's all I've got for now. I'll replace it at some point soon.
    All switches are NC so if I get a break I'll know about it.
    As for 4 core from Igus:
    https://www.igus.co.uk/product/1088?artNr=CF886.15.04
    https://www.igus.co.uk/product/1084?...270.UL.15.04.D
    https://www.igus.co.uk/product/950?artNr=CF6.15.04
    Stocking doesn't look that great there either. Seems about it from a brief search.
    Get some normal grey and overcover it with coloured heatshrink.
  12. The Following User Says Thank You to dazp1976 For This Useful Post:
  1. New build help needed
    By arg123 in forum Gantry/Router Machines & Building
    Last Post: 07-01-2016, 01:13 PM
  2. What's needed for a 3d printer build??
    By Davek0974 in forum 3D Printing Machines
    Last Post: 18-02-2014, 11:54 AM
  3. BUILD LOG: my router build - advice needed
    By thomashomer1986 in forum DIY Router Build Logs
    Last Post: 02-12-2013, 11:45 PM
  4. RFQ: Help needed to build my first machine NE Norfolk
    By Dorg in forum Projects, Jobs & Requests
    Last Post: 31-10-2012, 09:30 AM
  5. WANTED: Needed for my build
    By jpcnc in forum Items Wanted
    Last Post: 08-01-2011, 02:22 PM
