Thread: HELP NEEDED!!! for new cnc build
Coloured cables will be expensive and not easy to find in UK, plus they all do the same job so save your money and spend it in areas which will make the machine better.
You don't give any details so difficult to recommend sizes but in general, you'll use 0.5mm/2 for signal wires in the control box, 0.75mm/2 for Limits, motors, etc, and between 1mm/2 and 1.5mm/2 for the spindle.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
	09-01-2022 #2
Oh. I'm setting up for using cat7 solid core shielded ethernet for limits.
Think I'll have to do a little trial to check it doesn't burn up first before attaching to machine then.
I've used 0.5mm for control box (RS components, grey) and 1mm for steppers.
I think my servo is 1.5mm.
And yes. The UK is total crap or overpriced for supplies.
	09-01-2022 #3-use common sense, if you lack it, there is no software to help that.
	10-01-2022 #4
It's all I've got for now. I'll replace it at some point soon.
All switches are NC so if I get a break I'll know about it.
As for 4 core from Igus:
https://www.igus.co.uk/product/1088?artNr=CF886.15.04
https://www.igus.co.uk/product/1084?...270.UL.15.04.D
https://www.igus.co.uk/product/950?artNr=CF6.15.04
Stocking doesn't look that great there either. Seems about it from a brief search.
Get some normal grey and overcover it with coloured heatshrink.
The Following User Says Thank You to dazp1976 For This Useful Post:
New build help needed
By arg123 in forum Gantry/Router Machines & BuildingReplies: 27Last Post: 07-01-2016, 01:13 PM -
What's needed for a 3d printer build??
By Davek0974 in forum 3D Printing MachinesReplies: 26Last Post: 18-02-2014, 11:54 AM -
BUILD LOG: my router build - advice needed
By thomashomer1986 in forum DIY Router Build LogsReplies: 10Last Post: 02-12-2013, 11:45 PM -
RFQ: Help needed to build my first machine NE Norfolk
By Dorg in forum Projects, Jobs & RequestsReplies: 3Last Post: 31-10-2012, 09:30 AM -
WANTED: Needed for my build
By jpcnc in forum Items WantedReplies: 9Last Post: 08-01-2011, 02:22 PM
