With cnc on a cross slide is the digital readout set up to measure the actual diameter of the part, or the size of cut, (ie the movement is half the digital readout)?
https://www.youtube.com/watch?v=o5AXKYctOMs
10-01-2022 #2
10-01-2022 #3
Hi Clive thanks for the reply,
In the case of my SZGH CNC1000TDb it uses: set P16 on User parameters,diameter or radius programming.
The stepper pulses need to be matched at 10,000 on the stepper drive and in Axis Parameter No.17 Numerator of X Electron gear also set to 10,000.
I will set the No18 moved distance in diameter (P16) and see if that is correct.
Regards
Colin
Sieg KX-3 cross (Y) travel increase
By SteamCAD in forum Sieg Milling MachinesReplies: 2Last Post: 08-05-2019, 05:23 AM -
SBR20 measurement
By kingcreaky in forum General DiscussionReplies: 3Last Post: 17-07-2013, 05:42 PM -
spindle cross section view
By routercnc in forum Tool & Tooling TechnologyReplies: 20Last Post: 05-08-2011, 12:55 AM -
Spindle Speed Measurement
By clockmaker in forum Spindles & Drive MotorsReplies: 2Last Post: 04-12-2010, 11:38 PM -
Digital protractors/angle measurement - worth buying or not?
By irving2008 in forum General DiscussionReplies: 2Last Post: 15-05-2010, 07:26 PM
