Thread: Timing belt instead of rack!
	17-12-2009 #1Hi All.
 Been thinking(bad for me) and I thought why not use a timing belt for the X-axis on a router system. Two lengths of belt could be stretched along each side of the X-axis and interconnected timing pulleys could supply the drive.
 So is this feasable and what backlash would be in the system, the pulleys could also negate the need for a bearing as they would run along the belt.
 Not sure about tensioning the belt as yet just in the thinking stage.
 peter
	17-12-2009 #2Have a look at Mike Everman's belt drive here:
 [ame="http://www.cnczone.com/forums/showthread.php?t=59570"]Best belt drive ever! (If I do say so myself) - CNCzone.com-The Largest Machinist Community on the net![/ame]
	17-12-2009 #3Similar to my idea but he's using 2 belts which will up the cost plus the extra bearings used.
 Also makes mention of reducing backlash etc.
 Just had a thought against my idea lack of actual drive as only one tooth would be in contact.
 Back to drawing board!
 peter
	17-12-2009 #4Similar to my idea but he's using 2 belts which will up the cost plus the extra bearings used.
 You can use one belt but it still needs to wrapped around the pulley, this causes probems with backlash due to the belt stretching and sagging. (and between belt and pulley)
 In the other design two belts (or 1 cut in half ) are required to solve this and increase the tooth count on the pulley. The bottom belt is fixed and acts as a rack. the top belt is used for driving and the bearings force the top belt back down to mesh with the lower one forming a solid. Belt stretch is greatly reduced as it is only the small portion over the pulley and the sagging is removed. one thing to watch is that the belt can take back bending. ) are required to solve this and increase the tooth count on the pulley. The bottom belt is fixed and acts as a rack. the top belt is used for driving and the bearings force the top belt back down to mesh with the lower one forming a solid. Belt stretch is greatly reduced as it is only the small portion over the pulley and the sagging is removed. one thing to watch is that the belt can take back bending.
 As you pointed out this all added up and I have mainly seen it used on on large machines where ball screws would need to be massive. you could compromise and just provide support for the belt to remove the sagging.
	17-12-2009 #5Have you considered a chain rack? Something like this:
	17-12-2009 #6Now thats an ideaHave you considered a chain rack? Something like this: is that a normal bike chain and turned down spocket, or a special? is that a normal bike chain and turned down spocket, or a special?
 Have you used it? and do you Know accurate is it?
	17-12-2009 #7I made it in pixelanium and, as designed, has negative backlash thus improving any machine that it is fitted to by 1000%Have you used it? and do you Know accurate is it?
 The chain is normal, but the sprocket isn't a normal profile because the chain doesn't wrap around it. The profile shown is only a rough approximation.
 Bill
	17-12-2009 #8Nice idea on the chain but my original thought was to kill 2 birds with one chain so to speak in that the pulley running on the belt would effectively act as a bearing. You would still neeed another lower down to give some rigidity but the 2 belts per side increases the complexity and I was after simplicity mind you I realise that simplicity and accuracy dont go hand in hand.
 Mind you ball screws are just not cheap enough.
 Peter
	18-12-2009 #9Have a look at roller nuts:I realise that simplicity and accuracy dont go hand in hand.
 http://www.cnczone.com/forums/showth...t=13593&page=2
 This is a very long thread, but an interesting read with some good ideas for low cost alternative to ball-screws.
 If you could rig up some kind of positional feed-back (i.e. from a linear scale) then you could use a traction drive.my original thought was to kill 2 birds with one chain so to speak in that the pulley running on the beltLast edited by BillTodd; 18-12-2009 at 12:55 PM.
  6m X axis Rack and pinion or belt drive?By charlieuk in forum Rack & Pinion SystemsReplies: 6Last Post: 02-07-2020, 01:22 AM
  Calculating timing belt lengthsBy Jonathan in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 10-12-2015, 11:32 AM
  Timing Pulley/Belt sizing softwareBy m_c in forum Computer SoftwareReplies: 4Last Post: 12-04-2014, 03:33 PM
  timing belt instead of lead screwBy deannos in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 06-03-2012, 08:25 AM
  Timing belt drive concept, would this work?By psiron in forum Belt Drive, Pulleys & TimingReplies: 8Last Post: 16-06-2010, 03:31 PM
