Thread: Re-Building Suregrave CNC
15-01-2022 #3
Before buying a spindle are you sure the gantry and in particular the Z-axis is strong enough because these Suregrave machines were built for engraving not cutting?
Both the 1.5 and 2.2Kw spindles are much heavier and longer than the engraving spindle and DC motor that would have been originally fitted, in particular, the length which will act as a long lever and if I recall the gantry uses a narrow rail system which doesn't offer much support for the Z-axis. If the backplate isn't supported well enough or strong enough or any part of the Z-axis is weak it will cause vibrations at the tool which will result in broken tools and a poor finish. Having a heavy and long spindle will exaggerate and quickly show up a weak Z-axis.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
WANTED: Dahlgren dsc2000 black box to drive Gryphon suregrave router
By relayman in forum Items WantedReplies: 13Last Post: 08-12-2023, 11:09 AM -
Rebuilding gantry type Suregrave engraver - advice needed!
By GordonB in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 14-06-2020, 04:52 AM -
Suregrave Excalibur DT (2516i) with DSC2000
By DiGi5670 in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 16-08-2017, 11:28 PM -
FOR SALE: SUREGRAVE 2516I cnc/ router
By Lesley ungi in forum Items For SaleReplies: 1Last Post: 15-07-2017, 08:56 PM -
Suregrave cnc router
By terry1956 in forum Machine DiscussionReplies: 13Last Post: 24-05-2017, 03:19 PM
