20-01-2022 #10
Angular Contact.
I made my own bearing blocks (23mm thick with 2mm wide internal ridge) from 1 inch alloy stock.
Fitted 2x 7201-B-2RS in each for use on 1605 screws. Back to Back.
Adjusted preload on DFU with bits of 0.01mm thick alu foil between the nuts.
These are the screws and seller I used on x,y,z
https://www.ebay.co.uk/itm/263083205...4AAOSwal5YEjRE
(I think I got a slightly shorter 700mm one for z)
Haven't tried their 2005 ones. My 25 mill was fine with all 1605.Last edited by dazp1976; 20-01-2022 at 08:55 PM.
mill with no quill conversion
By mcmental76 in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 21-08-2021, 06:00 AM -
CNC conversion AMAT25LV AMAT30LV WM18 advice needed for total novice
By Hulksmash in forum Milling Machines, Builds & ConversionsReplies: 19Last Post: 18-12-2018, 12:31 PM -
CONVERSION: Sx3 mill conversion
By dazza in forum Conversion Build LogsReplies: 1Last Post: 29-04-2014, 10:23 AM -
Mill conversion to cnc
By wolsey in forum General DiscussionReplies: 1Last Post: 15-08-2011, 11:07 PM -
Help with drill-Mill conversion
By Ross77 in forum Milling Machines, Builds & ConversionsReplies: 134Last Post: 02-04-2010, 10:25 AM
