Not the case because they will happily run from a 3 phase rotary converter. Yes, this up's the cost but this is offset because of not messing around with converting, etc plus you get a real CNC machine, not a Dinky toy.
The mechanics are not much different from any other CNC machine, the principles are exactly the same the differences being they are stronger and better built with accurate datum edges, etc.
Given a choice between an old Bridgeport and a Haas Minimill I'd take the Bridgeport every time. The Haas is just a beefed-up Benchtop Minimill that sits on a steel frame.
The bridge port is one big lump of solid cast iron that will last forever and absorb vibrations like a sponge, it will give finishes and allow material removal rates the Haas Minimill could only dream about.
However, that was just one example and probably not the one I would go for either because there are better newer options if you watch for them, but the point is I wouldn't sink £3.5k which will quickly turn into £5k in all reality into a Chinese machine made from cast iron that is more brittle than a crunchy bar and about as stable as a quivers jelly when you can buy rock-solid old iron for not much more.
In all reality for someone wanting a small desktop machine then Denfords, Boxfords, Emco's, etc which are built from quality cast iron and with decent base components is probably the better way to go.
I'd just avoid converting a Chinese manual machine because it will always be a compromise at best and at worst it's a pig's ear that can't be turned into a silk purse no matter how much money you throw at it.!-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
mill with no quill conversion
By mcmental76 in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 21-08-2021, 06:00 AM -
CNC conversion AMAT25LV AMAT30LV WM18 advice needed for total novice
By Hulksmash in forum Milling Machines, Builds & ConversionsReplies: 19Last Post: 18-12-2018, 12:31 PM -
CONVERSION: Sx3 mill conversion
By dazza in forum Conversion Build LogsReplies: 1Last Post: 29-04-2014, 10:23 AM -
Mill conversion to cnc
By wolsey in forum General DiscussionReplies: 1Last Post: 15-08-2011, 11:07 PM -
Help with drill-Mill conversion
By Ross77 in forum Milling Machines, Builds & ConversionsReplies: 134Last Post: 02-04-2010, 10:25 AM
