  1. #21
    Quote Originally Posted by Monty_UK View Post
    Hey Jazz
    Aluminium, engineering plastics and some mild steel - I imagine the most common will the aluminium though. I had considered changing the main drive after the CNC to get higher speed and more constant torque
    Well in that case I would look long and hard before buying a Mini mill because very few will have the RPM you need for cutting aluminium and soft materials correctly and converting the spindle is not a simple or cheap thing to do.
    If you want a challenge you may be better off DIY building a strong Fixed gantry Router/Mill that will do everything you need and then some with the correct spindle fitted. It will certainly be more versatile and useful than a converted Minimill and won't cost much more. Here's one I built a few years ago (yellow one) with a 500 x 500 cut area and also one we built recently that is fully covered designed exclusively for cutting Aluminium moulds with a cut area of 600 x 400 which is more or equal to many industrial CNC machines but fits in a 1mtr/2 space.!
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  1. mill with no quill conversion
    By mcmental76 in forum Milling Machines, Builds & Conversions
    Last Post: 21-08-2021, 06:00 AM
  2. CNC conversion AMAT25LV AMAT30LV WM18 advice needed for total novice
    By Hulksmash in forum Milling Machines, Builds & Conversions
    Last Post: 18-12-2018, 12:31 PM
  3. CONVERSION: Sx3 mill conversion
    By dazza in forum Conversion Build Logs
    Last Post: 29-04-2014, 10:23 AM
  4. Mill conversion to cnc
    By wolsey in forum General Discussion
    Last Post: 15-08-2011, 11:07 PM
  5. Help with drill-Mill conversion
    By Ross77 in forum Milling Machines, Builds & Conversions
    Last Post: 02-04-2010, 10:25 AM
