  1. #23
    Quote Originally Posted by Monty_UK View Post
    Its amusing that this is where i started - then the thought process led me down the path of buying a machine and converting it :)
    I missed this post.!
    Yes, it's funny how things are initially conceived but then go off at tangents, I see this all the time with customers, esp new users, who buy machines with a plan to use them for ideas they have but within a few months or certainly within a year when they realize just what a CNC machine allows and it takes them down paths they never even thought about or knew existed.
    Converting works provided you buy the right machine to start with, but I've yet to see a good Mill come out of China.
    The problem with converting a manual Mill is they were never designed for CNC in the first place so often you struggle to fit ball-screws and motors mounts etc without the castings or beds needing material removing and it's here when the shit hits the fan.?
    The cast iron and steel are of very low quality and the casting doesn't undergo any stress-relieving so when you start removing material they have a tendency to shape-shift and twist etc.
    Even buying machines from UK based companies like Warco or Chester tools, Axminster, etc doesn't help this because they are just made in China with the same low-quality iron, this is why I recommended looking at used machines like Denfords or Boxfords because the castings are made in the UK with good quality ductile cast iron and stress relieved.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  1. mill with no quill conversion
    By mcmental76 in forum Milling Machines, Builds & Conversions
    Last Post: 21-08-2021, 06:00 AM
  2. CNC conversion AMAT25LV AMAT30LV WM18 advice needed for total novice
    By Hulksmash in forum Milling Machines, Builds & Conversions
    Last Post: 18-12-2018, 12:31 PM
  3. CONVERSION: Sx3 mill conversion
    By dazza in forum Conversion Build Logs
    Last Post: 29-04-2014, 10:23 AM
  4. Mill conversion to cnc
    By wolsey in forum General Discussion
    Last Post: 15-08-2011, 11:07 PM
  5. Help with drill-Mill conversion
    By Ross77 in forum Milling Machines, Builds & Conversions
    Last Post: 02-04-2010, 10:25 AM
