There may be a Warco WM18 on ebay ending soon (same sizes as WM32 I believe). Not sure on condition but states low use.
It's downfalls are MT3 taper and gear driven.
Looks in need of a right good clean but also means it might go cheap!.
https://www.ebay.co.uk/itm/125101856...YAAOSwbKNh4tn2
https://www.warco.co.uk/milling-mach...g-machine.html
MT3 no problem unless thinking tool changers or quick change as it's not that easy to release tools via drawbar unlike R8.
Gear driven may be easy enough to belt convert later.
Plenty info about that when searching G0704 belt conversion (25 size machine). Similar process, smaller size.Last edited by dazp1976; 21-01-2022 at 03:47 PM.
mill with no quill conversion
By mcmental76 in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 21-08-2021, 06:00 AM -
CNC conversion AMAT25LV AMAT30LV WM18 advice needed for total novice
By Hulksmash in forum Milling Machines, Builds & ConversionsReplies: 19Last Post: 18-12-2018, 12:31 PM -
CONVERSION: Sx3 mill conversion
By dazza in forum Conversion Build LogsReplies: 1Last Post: 29-04-2014, 10:23 AM -
Mill conversion to cnc
By wolsey in forum General DiscussionReplies: 1Last Post: 15-08-2011, 11:07 PM -
Help with drill-Mill conversion
By Ross77 in forum Milling Machines, Builds & ConversionsReplies: 134Last Post: 02-04-2010, 10:25 AM
