So 3 good tips then so far.
1. Keep machines off network (transfer files via usb).
2. Chewing gum in lan port.
3. IT department... 'bugger off'.
25-01-2022 #2
Hi Kate, We are based not too far away in Goole and could help with taking a look but much of what has been suggested regards keeping the machines off the main school network is good advice. Like iain1mm suggests using either memory sticks, which is the preferred method, or a local switch network with a wireless setup just for transferring files between machines would work well. Although I don't think I would go to all the trouble and expense of a switch setup just for 2 machines.? But it does offer scalability.!
Regarding Mach3 training then Mach3 or any other control software like UCCNC is just the machine's control software which means its main function is to interpret the G-code file and execute moves along with monitoring any switches that are fit on the machine, like Datum (home) switches, etc.
So after the machine has been set up by the engineers who commission the machine there isn't much user involvement that requires a lot of training. Yes mach3 and UCCNC etc are very complex software in terms of setup for the engineer but from the user's side in actually using the software and working the machine there isn't a lot to learn.
We build CNC routers that use UCCNC software which is very similar to mach3 but much better and far more reliable and within 30mins can teach first-time users what is required to use the machine and cut parts. The Creation of the G-code and CAM side is where all the learning will be needed and this will depend on the software you use.
If I can help drop me an email which is in my signature.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Old software for Denford machines
By phill05 in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 06-09-2021, 09:33 PM -
NEW MEMBER: New to CNC - advice on machines and software and other bits
By WillWW in forum New Member IntroductionsReplies: 0Last Post: 14-02-2021, 11:33 AM -
What software do you use on these chinese machines
By AlanJ in forum Chinese MachinesReplies: 10Last Post: 23-08-2020, 01:32 PM -
Nema 34 upgrade issues
By Mr*Beaver in forum Motor Drivers & ControllersReplies: 7Last Post: 18-03-2020, 07:45 PM -
Newbie. Questions about design software and machine control software
By MTech in forum Computer SoftwareReplies: 2Last Post: 11-12-2012, 12:58 PM
