    Can anybody tell me what causes these tramline marks between passes? The chamfer is a 32mm V bit and the profile a 4mm end mill. Both are leaving marks. I’m not sure what I’ve done. I’m pretty sure this is a recent thing.Click image for larger version.
    Thanks for your help.
    Hi Bruce,
    You haven't knicked the cutting edge have you, those marks on the chamfer look like the blades have hit a nail or something in the material.?
    It's hard to see on the sidewalls because it just looks like grain tear.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Thanks Dean. I don’t know. It happened with both tools. It’s caused a little groove on the chamfer between passes. I only had the piece heat glued down. I wonder if it was moving? It looked solid.
    RobC's Avatar
    Lives in Leeds, United Kingdom. Last Activity: 12-05-2024 Has been a member for 7-8 years. Has a total post count of 118. Received thanks 16 times, giving thanks to others 21 times.
    I get them on passes like such, if you are not able to solve the issue leave a radial rough cut at say 0.1mm and come back with a finish pass at full depth to clean them up.
    Quote Originally Posted by BruceR View Post
    Could be a number of things but yes if it was shifting about from tool pressure that would cause something similar but if it keeps happening you have my number give us a ring and we'll help you work it out.
    The suggestion from Rob to leave material for a finish pass is a good idea and nearly always gives a nicer finish and something I would recommend on anything you want a good finish or if hard or fluffy stringy material.
    I'd like to see a plan view image.My initial suspicion is either a tool length discrepancy or a slight tramming runout.It seems a bit odd that the spacing of the marks looks quite evenly spaced as the cut proceeds down.The suggestion to leave a little material for a finishing pass may well be enough to eliminate the problem.
    Thanks Rob. I’ll do a small project on Monday and do a final pass. Thanks for your help.
  8. The Following User Says Thank You to BruceR For This Useful Post:
  9. #8
    Thank you. I’ll have another look at it. It’s a pain. It doesn’t look much but it means I need to do a lot of sanding and it didn’t happen before. Thanks for your help.
  1. Plastic Chair Injection Molding Issue - White Marks
    By steppenwolf in forum Moulding Machines
    Last Post: 14-04-2022, 04:20 AM
  2. Opto isolated Bob and drivers causing a strange fault.
    By lucan07 in forum General Electronics
    Last Post: 02-05-2016, 09:28 PM
  3. Roundover finishing - what's causing this..?
    By Wal in forum Woodwork Discussion
    Last Post: 18-03-2014, 03:37 PM
  4. New Computer Causing Me A Big Problem
    By audioandy in forum Computer Hardware
    Last Post: 17-08-2010, 09:12 PM
