    Hi
    After wasting a couple of days trying to learn post processor editing and getting nowhere - I'm hoping someone maybe able to support me
    Does anyone have a Denford Novamill Fusion 360 post processor?
    Fusion 360 offer a generic Denford post processor which is probably close enough but it has un-supported G codes which I would need to remove.
    Couple of questions on post processors:
    I'm a little confused - The Novamill does not support arcs, if I delete this function from the post processor, and the function is required to generate a toolpath, how does the generator know to select a different option?
    What happens if I delete a G code that is mandatory to the generation of a toolpath?
    I'm using Denford VR Milling V5 software to control machine, it will still run code which includes unsupported G codes (G18 and G43 for instance), I'm assuming it will throw up an error when it comes up against a compulsory code?
    Chris
    Lives in East Lothian, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    I never used F360 with my Novamill, but VR Milling 5 does support arcs.
    Have you tried a generic Fanuc post processor?
    Interesting, during my dive down the rabbit hole trying to understand things and collect info, I read somewhere that arcs are not supported, but yes I can now see that they are thanks.
    I can see Fusion has several Fanuc post processors: Fanuc compact, with G91, inspection, or turning. I'll look into these.
    It's likely the generic Denford post processor will do the job fine but I don't have the experience to decide.
    What software do you use?
    I sold my Novamill years ago, but at the time I was using CamBam for generating code.
    All you can do if you're not sure, is run the code and cut air. Any issues should show up pretty quickly.
    VR milling has a VR machine but I can't seem to find a fast forward option so you have to run it real-time. I noticed the tool do some weird things like randomly plunge to the bottom of the stock at the beginning then work up from there before retracting and beginning from the top. Highly likely my fault for setting something wrong but it's these findings that made me realise I need to understand things a bit better to gain confidence.
    Thanks for the help
    That sounds like a tool offset issue.
    How does the movement look in F360?
  1. Fusion 360 post processor
    By f750 in forum Fusion 360
    Last Post: 22-07-2021, 10:57 AM
  2. Post processor
    By DaveC in forum Tool & Tooling Technology
    Last Post: 03-08-2019, 09:43 AM
  3. Replies: 8
    Last Post: 26-12-2017, 02:12 PM
  4. Help with Post Processor
    By superpot in forum CAD & CAM Software
    Last Post: 20-11-2013, 11:23 AM
  5. Post processor Sei
    By 2006Nobull in forum Machine Discussion
    Last Post: 04-08-2011, 12:58 PM
