Thread: 6040Z HELP please
31-01-2022 #2
I don't know this controller or software, so can't help with the setup but If you are using a USB controller then you shouldn't need to convert from parallel to USB. Just connect the USB cable directly and install the plug-in for mach3 and it should work.
If you are trying to use Mach3 parallel port driver then it won't work with Win10 or Any 64bit version of windows. Also, as you have found mach3 won't work with a parallel port to USB converter.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
6040Z USB CNC - USB port not recognised.
By Roy in forum Chinese MachinesReplies: 9Last Post: 23-05-2021, 10:04 AM -
6040Z controller
By RichardR in forum Control Hardware & SystemsReplies: 70Last Post: 01-11-2020, 10:38 AM -
6040Z controller
By RichardR in forum Control Hardware & SystemsReplies: 0Last Post: 19-10-2020, 02:36 PM -
6040Z USB connection issues
By rogw in forum Chinese MachinesReplies: 8Last Post: 01-08-2019, 08:30 PM -
CNC 6040z USB z-axis
By Sashido in forum Chinese MachinesReplies: 19Last Post: 26-03-2018, 09:46 AM
