Thread: Help Mach3
    Why'd you get the P, O, S, TB6600?.
    https://m.aliexpress.com/wholesale/T...tml?osf=direct
    Hope you didn't pay too much.
    Should've saved yourself aggro and just gone with 542 or 556.
    You get what you pay for.
    Lives in East Lothian, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Quote Originally Posted by dazp1976 View Post
    As I've said numerous times before, TB6600 are OK drivers, yet you seem to want to say they're rubbish at every opportunity.
    They are by no means a high performance driver, but they're a reasonable basic stepper driver.
    It was the older TB6560 which was well known for failing, but that was mostly down to people trying to run them on too high a voltage. If you actually ran them within their operating voltage range, they were an OK driver.
    Not every application needs maximum voltage or performance.
    Hi dazp,
    I now have all axis working fine. I connected stop limts, probe for hight of tool but none of them work. I wired them as per manual still nothing, Have i missed somthing?? I have attached the manual for you to look at
    Regards
    Mike
    Mach3-5-Axis-Interface Board.pdf
    Quote Originally Posted by Mikes Planes View Post
    Hi dazp,
    Regards
    Mike
    Do you have a 12-24v power supply plugged into the middle 2 screw terminals on the right hand side?.
    If not, that is your problem. Inputs are powered by this. Only the outputs use the 5v power.
    They are 2 separate circuits.
    Around a 2Amp supply should be plenty.
    Missing out this power supply is a common problem.
    Sorry foe being so long to say thank you all in last post now working. Sorry stiil have problems. I have wired all axis up but Z only go's up I have tried plugs and pin and also looked in Homing and limits no luck.
    Mike
    Mike
    Broken wire or pin between controller and driver DIR terminal?.
    Controlling the stepper DIR simply works by switching the 5v on or off to the drive DIR terminal. So a broken wire is the first place I'd start.
