Thread: Help Mach3
04-03-2022 #2
Hi Thanks for that, My steppers are 60BYG301B
Mike
04-03-2022 #3
05-03-2022 #4
04-03-2022 #5
Ah!!!!.
I see 8 wires.
Best balance for both speed/torque is parallel. Also lowers your inductance. Twist pairs together and connect as folliws:
A+ RED & BLU
A- YEL & BLK
B+. WHT & BRN
B- ORG & GRN
Then 10-45v power supply in the other 2 terminals (marked 32v & GND I think).
Try that.
I see your motors are 3.2mh inductance in parallel (it's lowest level avail). Not great for trying to get fast rapids on only 36v or less. Fine for general cutting speeds.Last edited by dazp1976; 04-03-2022 at 04:14 PM.
04-03-2022 #6
This may help-
https://cnc4you.co.uk/resources/Step...1B%203.1Nm.pdf
05-03-2022 #7
Hi All,
Thank you all so much for your help. I don't seam to be getting anywere with what I have, I can get full movement on Y axis using Z port on the settings I was using??
If my breakout board is OK then what drivers should I buy??
I am so upset with all this as when we left UK it was running so well. I dont have the money to buy a new Geko and even if I did I have a deep feeling it would not fix things and I would be where I am now but having spent lots of money.
Thanks again guys you have all been a help.
Mike
05-03-2022 #8
Without a doubt this one. The stepperonline drive is very good and priced well atm.
https://www.omc-stepperonline.com/di...r-motor-dm556t
It shows in the pdf wiring for a 6 lead motor which means it supports unipolar. I also looked at the pdf of gecko 540 and it also had 6 wire wiring examples.
This is possibly why TB6600 isn't happy, it doesn't support it.
So. DM556T driver and myself I'd try it wired half coil.
https://www.omc-stepperonline.com/download/DM556T.pdf
The drive is available from stepperonline in the EU and it is also available on Aliexpress.
https://m.aliexpress.com/item/100500...001422484003.0
I more or less get everything from Aliexpress these days.
I've given up with UK. Availability is awful, mostly has the cheap stuff, and also at stupid pricing.
You could get the DM542T but the 556 is better value. Price difference is negligable and your motors look like they are 4.2A which is full on the 542. If your motor heat is low at 4.2 you have nowhere to go with it. The 556 gives you options.Last edited by dazp1976; 05-03-2022 at 03:58 PM.
05-03-2022 #9
06-03-2022 #10
No I have four, After putting wires together I now have four. I was wrong I do have eight wires on motor.
Mike
