Thread: Help Mach3
    Hi
    Thanks for that.
    If I put the Z axis on to the Y axis on the board it works perfectly does this mean there is somthing wrong with the board???
    Mike
    Quote Originally Posted by Mikes Planes View Post
    Hi
    Thanks for that.
    Mike
    If you are absolutely sure you have the correct pin numbers for the Dir pin and when you replace the wiring and it still doesn't work then yes it's a good indication there is something wrong with the Dir output pin.
    Highly likely you have the wrong pin number if it's the first time using it, but if it was working before with this pin number then most probably dead output.!
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
