Thread: Help Mach3
This one?
Yes.
PC+ (5V+) To ALL pul+, Dir+ (&En+ if you use it) on the drives.
Pul- (pins 2,4,6,8 on board) to Pul- on drivers.
Dir- (pins 3,5,7,9 on board) to Dir- on drivers.
For En- I used p14.
Or the little white plugs. Mine are marked +5v, CLK, CK, EN. (CLK is pul, CK is dir).
Then used p16 for coolant and p17 for a relay NC position (had grief with the onboard)
Is all here:
https://warp9td.com/images/BOB_Vendo...line/ST-V2.pdf
To be honest. ANY board that has pulse, direction, enable, 5v+, 5v-, can run a stepper driver.
