Thread: Help Mach3
13-07-2022 #29
Ah didn't realize you were using the parallel port. Well in that case then if it does it with both boards and you are sure the pin number is correct it most likely will be a faulty cable. The cable must be what's called a Null modem cable, which basically means that each pin goes to the same numbers at each end of the cable. Some cables cross over ie: pin1 to pin 10 at the other end. This is easily checked with a multimeter continuity test.
Email: [email protected]
Web site: www.jazzcnc.co.uk
