	03-03-2022 #1Hey everyone,
 Quick sanity check. I know signal wires don’t need to be particularly beefy however I'm switching my motors over to JMC servos which have the driver built in, so I wasn't sure if this changes things. I use my setup for video production not CNC hence cables are quite long, 7 metres. I'll be using separate cables for power and signal.
 For signal I was planning to use 6 core cable for; stp, dir, gnd, enable, disable, and then cable ground (grounding shield to star point in control box). Will this cable be ok? Not sure if 25 AWG is too thin.
 https://cpc.farnell.com/pro-elec/pel...00m/dp/CB22673
 These are the motors:
 https://www.aliexpress.com/item/JMC-...64ad4c4dxzlvpE
 https://www.aliexpress.com/item/4000...64ad4c4dxzlvpE
 One other quick question. DC power to these drives is just two cables V+ and V- there's no ground run to the motor, or is that V-? SOrry for the obvious question, it's been ages since I've done this.
 Thanks for the help
  Stepper motor Pulse Signal Generator moduleBy Tom J in forum Motor Drivers & ControllersReplies: 8Last Post: 12-01-2016, 11:47 AM
  VFD to motor cable wire size (Gauge)By artman12us in forum Spindles & Drive MotorsReplies: 2Last Post: 24-04-2014, 07:11 PM
  What size servo motor do I need.By Jonathan in forum Stepper & Servo MotorsReplies: 1Last Post: 31-03-2014, 09:16 PM
  motor and spindle cable size?By paulus.v in forum General ElectronicsReplies: 4Last Post: 04-02-2014, 10:18 PM
  Cable Size ?By manofgresley in forum General ElectronicsReplies: 1Last Post: 09-05-2013, 02:55 PM
