01-03-2022 #2
I haven't really got the time to read all of the post so just quickly flicked through the images but I can see straight away that you are going to run into trouble with alignment and setup because you haven't got any adjustment so even with a machine to help you make parts you won't make them so accurate that you won't need some way to make adjustments.
The golden rule of DIY building is to allow for Adjustment, then a little more adjustment for good measure.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Many questions before I build my first milling machine
By iGyros in forum Machine DiscussionReplies: 13Last Post: 26-10-2020, 09:32 AM -
How Would You Upgrade An Old Ox CNC Build Into A Serious Machine?
By NeoMorph in forum Machine DiscussionReplies: 54Last Post: 01-03-2020, 09:29 AM -
New CNC build gantry questions
By Capsuna in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 04-12-2019, 12:59 AM -
A few questions before I start my build
By eclassic in forum General DiscussionReplies: 0Last Post: 11-07-2011, 10:54 PM -
NEW MEMBER: Hi from rainy York - build plans/questions
By bikepete in forum New Member IntroductionsReplies: 13Last Post: 11-10-2009, 07:43 AM
