    Lives in East Lothian, United Kingdom. Last Activity: 3 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    That's pretty much how it works.
    What you need are 5/2 valves, with a single solenoid and spring setup.
    Originally Triac's had a bank of 3 (or more depending on spec) modular valves in the cabinet (location depended on machine spec - PC were in a separate box on the rear of the machine, Full integrated machines would of had them in the main electrical cabinet), with two 5/2 valves for controlling the toolchanger in/out and up/down, and a 3/2 valve for actuating the drawbar.
    The valves on the rams themselves are flow control valves to control the speed of the ram as it moves, so they don't just slam into full travel.
    Thank you - I'll have a look at the 5/2 and 3/2 valves and try and get new ones as I'd rather replace with new.
    This is a PC version with the box at the back
    thanks again
    Every time I am wrong - the World makes a little less sense.
  1. Generic Chinese VFD, XSY-AT1 Programming Parameters/Settings
    By tarawa in forum Spindles & Drive Motors
    Last Post: 02-06-2023, 06:21 AM
  2. Replies: 14
    Last Post: 19-10-2017, 02:34 PM
  3. VFD Question
    By Chaz in forum Motor Drivers & Controllers
    Last Post: 14-01-2017, 08:41 PM
  4. 3020 / 3040 / generic chinese router accuracy
    By m_c in forum Machine Discussion
    Last Post: 24-07-2014, 11:54 PM
  5. question ...
    By Wobblybootie in forum General Discussion
    Last Post: 04-01-2010, 12:04 AM
