13-03-2022 #1
Hi All,
I have a problem with my cnc router machine.
It's not cutting to the correct depth.
It's barely scratching the wood regardless to what height wood i use, this is more noticeable when using various text fonts.
I even fit a touch plate to ensure the heights etc were correct and changed the relative info within the script to suite the plate height etc, but still had the same problem.
I'm sure this is a problem within Mach 3, but don't want to start altering settings unnecessarily, as I'm not that familiar with it.
If it helps any, I've noticed when using the touch plate, that after it finished and I click the, GO TO ZERO button, the machine goes to a few mm above the work surface instead of, more or less touching the wood surface.
Any assistance would be really appreciated , Cheers Yarlo
NEW MEMBER: CNC Router machine not cutting deep enough Mach 3
By yarlo in forum New Member IntroductionsReplies: 0Last Post: 12-03-2022, 07:52 PM -
Outer cut cutting too deep
By scapaflyer in forum Rails, Guideways & BearingsReplies: 1Last Post: 04-04-2018, 07:42 AM -
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM
