Name:	1-CL86T-34HS31 3-1000x1000.jpg
Name:	1-CL86T-34HS31 2-1000x1000.jpg
    This CNC kit included:
    1 x Closed Loop Stepper Driver 0~8.2A 24~80VDC for Nema 34 Stepper Motor
    1 x Nema 34 Closed Loop Stepper Motor 4.6Nm/651.54oz.in Encoder 1000CPR
    1 x 1.7 m(67") Long Encoder Extension Cable for Closed Loop Stepper Driver
    1 x RV-4 AWG18 1.7 m(67") Long Motor Extension Cable with GX16 Aviation Plug for Nema 34 Closed Loop Stepper Motors(Just for aviation-plug model motor)
    Motor Specification
    Manufacturer Part Number: 34HS31-6004D-E1000
    Motor Type: Bipolar Stepper
    Step Angle: 1.8 deg
    Frame Size: 86 x 86 mm
    Holding Torque: 4.6 N.m(651.54 oz.in)
    Rated Current/phase: 6 A
    Shaft Diameter: Φ14 mm
    Shaft Length: 40 mm
    Key-Way Length: 25 mm
    Phase Resistance: 0.3 ohm
    Inductance: 2.3 mH ± 20%(1KHz)
    Number of Leads: 4
    Lead Length: 300 mm
    Driving Voltage : 5V
    Output current : 55mA
    Resolution : 1000ppr
    Output Signal : 2 Channels
    Bore Diameter : Φ8mm
    Output Frequency : ≤1MHz
    Running Speed : ≤5000rpm
    IP Protection : IP20
    https://www.omc-stepperonline.com/cl...or-driver.html
Name:	23E1KIP65-12 1-1000x1000.jpg
ID:	26423 Click image for larger version.
Name:	23E1KIP65-12 3-1000x1000.jpg
ID:	26424Click image for larger version.
Name:	23E1KIP65-12 4-1000x1000.jpg
Name:	23E1KIP65-12 5-1000x1000.jpg
ID:	26426Click image for larger version.
Name:	23E1KIP65-12 6-1000x1000.jpg
    https://www.omc-stepperonline.com/wa...r-1000cpr.html
    Electrical Specification
    Number of phase: 2
    Step Angle: 1.8 deg
    Holding Torque: 1.2 Nm(169.97 oz.in)
    Rated Current/phase: 4.0 A
    Phase Resistance: 0.45 ohms
    Inductance: 1.4 mH ± 20%(1KHz)
    Physical Specification
    Frame Size: 57 x 57 mm
    Body Length: 65 mm
    Shaft Diameter: Φ8 mm
    Shaft Length: 21 mm
    D-Cut Shaft Length: 15 mm
    Lead Length: 1000 mm
    Weight: 0.8 kg
    Encode Control(1000CPR)
    Black--GND
    Red--+5VCC
    Blue/White--EA-
    Blue--EA+
    Orange/White--EB-
    Orange--EB+
Name:	17BK05-07 1-1000x1000.jpg
ID:	26431 Click image for larger version.
Name:	17BK05-07 2-1000x1000.jpg
ID:	26432 Click image for larger version.
Name:	17BK05-07 3-1000x1000.jpg
Name:	17BK05-07 4-1000x1000.jpg
ID:	26434 Click image for larger version.
Name:	17BK05-07 6-1000x1000.jpg
ID:	26435 Click image for larger version.
Name:	17BK05-07 7-1000x1000.jpg
    https://bit.ly/2md8s3P
    Number of phase: 2
    Step Angle: 1.8 deg
    Holding Torque: 72 Ncm(101.98 oz.in)
    Rated Current/phase: 2.0 A
    Phase Resistance: 1.75 ohms
    Inductance: 4.0 mH ± 20%(1KHz)
    Frame Size: 42 x 42 mm
    Body Length: 60 mm
    Shaft Diameter: Φ5 mm
    Shaft Length: 24 mm
    Number of Leads: 4
    Lead Length: 450 mm
    Weight: 0.5 kg
    Brake Connections
    Red--24V+
    Red--24V-
    0.5Nm
  1. Metal Supply - 1stChoiceMetals.co.uk - 10% Discount Offer.
    By 1st Choice Metals in forum Manufacturer News
    Last Post: 21-11-2016, 12:59 PM
  2. 10% Discount weekend At Zapp Automation
    By Gary in forum Marketplace Discussion
    Last Post: 19-02-2012, 12:42 PM
  3. Zapp Automation Discount Weekend !
    By Gary in forum Manufacturer News
    Last Post: 21-08-2011, 11:29 PM
  4. NEW MEMBER: Hello to all members
    By HUKBMBEAR in forum New Member Introductions
    Last Post: 24-08-2010, 05:00 PM
  5. NEW MEMBER: New Members
    By airwolf in forum New Member Introductions
    Last Post: 02-11-2009, 06:31 PM
