Thread: Coolant strength
27-03-2022 #9
Tell me about it, you should see the losses we get on our Hurco VMC. Between hot parts and a high-pressure coolant system, we are forever topping up the coolant, it's surprising how much you can lose just on the parts, even after blowing them off with air.!
But our biggest challenge and pain in the arse is contamination from the way-lube oil which is pumped to the linear bearings and ball-screws. It's a nightmare because while I can control the time the pump is on through the controls PLC I can't have it off for too long for the risk of killing the linear bearings so we get a film of oil on top of the coolant.
I'm trying to come up with a simple oil skimmer, so any ideas will be greatly appreciated.?-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Machine strength from DIY to chinese
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 10-10-2021, 11:17 AM -
coolant
By luke11cnc in forum Machine DiscussionReplies: 4Last Post: 11-02-2012, 01:17 PM -
Alu 40x40 frame - strength/design question
By Rogue in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-11-2011, 05:02 PM -
What coolant to use??
By don_jarr in forum General DiscussionReplies: 13Last Post: 05-11-2011, 03:12 PM -
Calculating Stepper Motor Power? Strength?
By antsals in forum General DiscussionReplies: 2Last Post: 11-07-2011, 12:18 PM
