This is brilliant! Thank you guys
I have been checking the discrepancy by measuring the distance from the end of the track to the carriage when the toolpath has finished.
The discrepancy increases the more complicated the toolpath is so that would back up your advice.
Also, yesterday I ran the machine with the right hand motor running as a slave to the left and there was no run out.
I've not noticed any difference when changing the speeds.
I will change the Active state and report back.
27-03-2022 #2
You need to do this in a methodical order. First, you need to identify if you are losing steps because of pulse timing problems or tuning/power/mechanical problems.
Forget your toolpath and just do the bounce test first by making a simple G-code program to move the axis back n forth, this will tell you straight away if it's a pulse timing issue and if it's not then you can move on and look else were.
Ok, you are giving confusing messages now.? So are you saying you were not using slaving before.? If yes then how were you doing it.?-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
27-03-2022 #3
Thanks so much for helping me with this.
Here's where I'm at.
Like you said I made a test toolpath that jogs the Y axis up and down 100 times.
First I ran it with motor A polarity reversed and sharing motor Ys signal from the control board. it worked fine.
Next I ran it with motor A slaved off motor Y with motor A step low activated and it lost steps.
Then I ran as above with motor Y step low activated and it lost slightly more steps.
27-03-2022 #4-use common sense, if you lack it, there is no software to help that.
cnc router x axis starting before y axis finished when pocketing ?
By Robin Oakapple in forum General DiscussionReplies: 16Last Post: 30-08-2020, 11:09 AM -
Triac VMC Servo // Z-Axis Dropping on power off
By danielbriggs in forum Machine DiscussionReplies: 6Last Post: 09-07-2018, 10:35 PM -
The right voltage for my Stepper Motors in order not to lose steps
By jhonansaro in forum General DiscussionReplies: 10Last Post: 11-12-2017, 08:48 PM -
Mysterious Z axis errors
By dachopper in forum General ElectronicsReplies: 11Last Post: 01-04-2017, 05:11 AM -
Losing steps on Z axis
By Arzo10 in forum Machine DiscussionReplies: 15Last Post: 31-03-2017, 10:49 AM
