28-03-2022 #13
Ok so you are using the parallel port now I'm not saying that is your problem, thou it's highly possible, but what I am suggesting is you do yourself a favor and buy an external motion controller like the AXBB-E which uses an Ethernet connection. Combine this with more volts for the steppers and you'll transform the machine into a different animal.
It will be more reliable and faster, you'll also be able to dump Mach3 and go with UCCNC software which is much better.
Now back to your issue.!
Because you are using the parallel port some of this could be because you have the machine overturned, So give us the settings you have for the motor tuning and the micro-steps set on the drives for each axis.
Also, have you checked the STEPS PER is correct by measuring it moves the correct distance told.?-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
cnc router x axis starting before y axis finished when pocketing ?
By Robin Oakapple in forum General DiscussionReplies: 16Last Post: 30-08-2020, 11:09 AM -
Triac VMC Servo // Z-Axis Dropping on power off
By danielbriggs in forum Machine DiscussionReplies: 6Last Post: 09-07-2018, 10:35 PM -
The right voltage for my Stepper Motors in order not to lose steps
By jhonansaro in forum General DiscussionReplies: 10Last Post: 11-12-2017, 08:48 PM -
Mysterious Z axis errors
By dachopper in forum General ElectronicsReplies: 11Last Post: 01-04-2017, 05:11 AM -
Losing steps on Z axis
By Arzo10 in forum Machine DiscussionReplies: 15Last Post: 31-03-2017, 10:49 AM
