    You guys have started to lose me with the Opto isolators chat, can you put it in layman's terms?
    Also the relevance of the frequency?
    I'm good at making stuff but electrical engineering and computers are not my strong point.
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 2 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    Apologies. This particular thread of conversation started with questions around signal integrity (pulse widths, and the like). That lead into a general concern if the breakout board (bob) might suffer in its design with the use of slow opto-isolators - devices that act like electronic switches, that would couple the stepper pulse from the computer to the stepper drivers. It’s a weakness in design that crops up from time to time and exhibits the problems you have witnessed. My post was simply to identify that these devices are not present on your bob, for the stepper driver signals, and that we shouldn’t get distracted with talks of changing bobs on the basis of an invalid assumption.
    Not at all...thanks for the clarification.
    Quote Originally Posted by Hatchett Job View Post
    The 2 big black spider looking things are buffers.
    The 5 little black things on the left with 4 legs are optocouplers.
    The buffers are to smooth things out.
    The optos can sometimes be slow and cause pulse problems. However, These boards don't use opto on the outputs so this is not your problem.
    In a nutshell.
    Optos allow 2 voltages to work together, it acts as a switch via a light diode.
    So you can use say 24v limit switches into the opto and then that can signal out to your 5v parallel port without it blowing up.
    Using the higher 24v on switches and the like helps to reduce false triggers as it is less susceptible to electronic interference from vfd's etc than a fully 5v system.
  1. cnc router x axis starting before y axis finished when pocketing ?
    By Robin Oakapple in forum General Discussion
    Last Post: 30-08-2020, 11:09 AM
  2. Triac VMC Servo // Z-Axis Dropping on power off
    By danielbriggs in forum Machine Discussion
    Last Post: 09-07-2018, 10:35 PM
  3. The right voltage for my Stepper Motors in order not to lose steps
    By jhonansaro in forum General Discussion
    Last Post: 11-12-2017, 08:48 PM
  4. Mysterious Z axis errors
    By dachopper in forum General Electronics
    Last Post: 01-04-2017, 05:11 AM
  5. Losing steps on Z axis
    By Arzo10 in forum Machine Discussion
    Last Post: 31-03-2017, 10:49 AM
