Page 1 of 4 123 ... LastLast
    Hi all
    Found these kits - was think of using a pair on all 3 axis - mines going to be hobbyist build!! - what are your thoughts
    Link https://vevor.co.uk/products/2x-line...37919746687175
    Well, they're certainly cheap, but if you're on a tight budget they'll be better than the skate bearing and angle-iron alternative that many people turn to. As you say, it's a hobbyist build so presumably isn't going to be running 24/7. You could always buy one set and check the quality before committing to all 3, the delivery time isn't too bad by the look of it.
    Kit
    Thanks Kitwin - I will give them a go
    Steve
    Quote Originally Posted by WoodKnot View Post
    Hi all
    Looks identical to this kit: https://www.aliexpress.com/item/1005...%2315609%23247
    Recently I bought a similar kit, but not from the same seller. https://www.aliexpress.com/item/1005...47344c4dvbomq4 I only needed 400mm long, and I must say that what I received is excellent, I am very happy with it.
    I try to avoid sellers with such low rate as 94%, but your stuff can be equally good as mine. 1000mm is pretty long, so it is more critical, but otherwise I think it should be fine. Mine are good quality. Kitwin is a bit negative... unless there is a manufacturing defect, to say that they are "better than the skate bearing and angle-iron alternative" is really nonsense. Of course they are better, even supported round bars are better, MUCH better. You can't compare with those under the same sun.
    That said, you should be prepared to clean the bearings. They can come dirty from the factory, but cleaning those linear slides is really no big deal. Generally, I think that good cleaning is always necessary, though these last ones I bought seems very nice and clean. All my bearings came individually packed, nice in sealed plastic bags, as well as all the other things, everything individually packed. I don't know if yours will be the same.
    That was my point, even the lowest quality rails of this design are going to be way ahead of any cheap, DIY construction that other builders turn to in order to save money. And I certainly hope supported round rails are better as well, that's what I'm using! Though If I'd seen these rails at that price when I built my machine I may well have chosen them instead.
    Kit
    I am glad that I misunderstood your comment before.
    Same here. Been using those for several years now, initially planned to replace them one day, but gave up the idea because I think they are just fine for my needs. My first CNC was based on unsupported round rods, and while they worked, and even could earn some money using them, I decided to upgrade to supported round rails. The results were satisfying and now, while it would be cool to have these HGR20 rails with HGH20C bearings, I think the work it demands to make the change is not worth it. Yes, these rails are fairly cheap today, but unfortunately it is not a "plug and play" work, but demands a serious modification of every axis. Maybe if something seriously goes wrong with the machine I'll do this as well as fixing the serious issue, but for now I'll be fine.
    Kit
    Yes, I'd definitely chosen these rails if they were as cheap as they are today. As I remember, these were a lot more expensive back in 2013 when I started with mine, and at that time I wasn't even sure that I really wanted a CNC. I just built one for my own mental challenge, to see if I can design, build and learn how to use one, so spending that much on something so totally "useless" thing was just not what I wanted to do. Today it's different. For all newly starters there is a gold mine out there, because really, we have to admit that those cheap Chinese things got a lot better in quality during the last years, so buying cheap is not necessarily the same as buying crap.
    Thanks A Camera -
    Ok, they are not a top brand and of course, for the price, it does make you question it. Like most stuff these days, it comes out of the same factories but with a different brand name. I am going start buying bits and pieces over the next few weeks to at least get he base machine built - still struggling on how the hell i am going to get my plates made with no cad ability??
    Thanks A Camera -
    True that (normally) you get what you pay for, but in this case, I think that if I'd spent 5-10 times more, I'd NOT get 5-10 times better stuff. I bought similar stuff before and this last buy is definitely miles ahead in quality. Last time (before this one) I had to open every bearing and clean each ball and everything because there was so much grit in them that they were grinding the rails and the balls. It was no fun with all those tiny balls in 16 bearings... but I managed without losing a single one. So the way I see it, that's the worst that can happen. Of course, a bent screw or rail is even worse, but I thing that's rare. Also, even if you had bad luck and received a bent screw, it is so cheap that you can buy a new one. In fact, you can buy several before you are up in the same price as the real high quality ones.
    So far I bought in total 8 ball screws (1204 and 1605) but never had any issues. But, as I said, all mine are shorter, the longest 1605 I bought is 650mm, so not very far from your 1000mm, but still shorter. One thing you should carefully consider is the travel distance and speed. With 1605 you need many turns from one end to the other, so you will need a lot of time, or very fast and powerful servo or stepper motors.
    Regarding no CAD-ability... I designed and built my CNC without CAD, just paper, pen and calculator. I never had the patience to spend a lot of time on fancy 3D CAD models. I understand when people work with that professionally and selling the machines or models, but for a one single machine, what's the point...? In fact, many things I made are made with manual G-code programming without any CAD. Some times I use simple 2D CAD and convert the DXF file to G-code, edit and correct or change manually the things needed to be changed. Among the tools I am using there is an old CAD software I bought about 20 years ago for about 20USD. That is my favourite for many jobs. After that comes FreeCAD, which is a free (donateware) but extremely professional and advanced CAD software. I use that mostly for 3D printed objects. That software I am so happy with, that every time there is an update I pay a sum (I think 20USD) because I consider those guys worth the money. But I never done any machine modelling. I just build them...
    Lives in Marple Stockport, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Hi all
    Have you checked what bearings are in the BK end bearings
    ...for that price...? I mean, seriously, if the bearings are crap you buy some SKF quality bearings and replace them. It's a 5 minute job. Mine are so far perfectly OK. I just bought another kit. This one:
    https://www.ebay.com/itm/393113635297
    Will get it by next week and I expect it to be as good as the previous ones, which I bought on Aliexpress and not from the same seller.
  1. Xzero Raptor CNC build - linear rail and ballscrew selection
    By Mattia in forum Gantry/Router Machines & Building
    Last Post: 27-08-2021, 01:34 PM
  2. 2m+ travel lengths with a ballscrew, using linear rail to support the ballnut
    By Desertboy in forum Rails, Guideways & Bearings
    Last Post: 04-02-2018, 06:50 PM
  3. 3 axis ballscrew and rail kits on ebay
    By Richard in forum Classified Ads, Buy, Sell & Swap
    Last Post: 18-05-2017, 02:06 PM
  4. NEW MEMBER: Hi,Friend,I'm a B2C seller from China for ballscrew,linear guide,linear shaft etc.
    By yvesleeok in forum New Member Introductions
    Last Post: 10-08-2013, 11:15 AM
  5. Linear rail and ballscrew dimensioning for R/C router
    By CarlNicholasCarlsson in forum Linear & Rotary Motion
    Last Post: 24-03-2013, 06:52 PM
