Thanks, you’ve given me a bit to think about, as you say there’s no perfect solution and there’s always a compromise.
I think for me space is probably the more important factor, it’ll be a bench top machine for hobby wood working, so I can take the hit on shallower passes and slower feed rates. If I start it off in the morning and it takes all day that’s not a problem as I don’t intend to do round the clock mass production where time is money.
Constitution wise whilst I can weld I want to go for a bolt together solution for two reasons; I only do woodworking these days, so don’t have a suitable facility for welding and grinding. Also I’ve a feeling that as I built and use the machine I’ll want to change things so going for bolt a together construction will allow me to make changes.
BUILD LOG: Build Log: 4'x4' Moving Gantry CNC Router
By GeorgeW21 in forum DIY Router Build LogsReplies: 14Last Post: 20-01-2019, 09:33 AM -
BUILD LOG: MK2: moving gantry router for metal cutting - comments sought!
By paulus.v in forum DIY Router Build LogsReplies: 20Last Post: 01-12-2018, 12:53 PM -
Moving gantry and table on the same axis - why not?
By suicidal_orange in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 02-02-2018, 12:20 AM -
Help Please for Moving Gantry
By endlasuresh in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 08-11-2017, 12:15 PM -
Now That's a Serious 4-Axis Moving Gantry Machine!
By magicniner in forum Machine DiscussionReplies: 6Last Post: 31-03-2017, 07:43 PM
