    Lives in Plymouth, United Kingdom. Last Activity: 3 Hours Ago Has a total post count of 1,747. Received thanks 298 times, giving thanks to others 11 times.
    I wonder how many of us "home" builders actually do inhibit the spindle during tool change? On my mill, I've configured the M6 macro to go to the tool change position, wait for manual tool change and hit the "change done" button (pop-up menu), then automatically set tool height via the tool-setter. On the router, I skip the tool-setter bit 'cos it doesn't have one. In both cases, I rely on the software/hardware not to spin up the spindle while I'm changing the tool. I'm sure that that is not acceptable in an industrial setting. Is that what everyone else does?
    You'd be surprised just how many industrial machines don't inhibit the spindle, especially routers.
    To be fair I think if they did have an inhibit switch very few would use it because they would be forever forgetting to turn it back on again before hitting cycle start and very few would put any checks in the M6 macro to see if the spindle was up to speed before letting the program run again.
    One of the things we do is wire our machines so hitting the RESET in the software doesn't drop the drive's power or inhibit them so they stay locked and position doesn't get lost, we then tell people to put the machine into RESET when changing tools this way the OUTPUTS are made safe( well safe as can be without a physical switch).
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  1. Xsy-at1 connection translation
    By GREG021 in forum Motor Drivers & Controllers
    Last Post: 17-02-2021, 02:10 PM
  2. Which Connection ?
    By manofgresley in forum Stepper & Servo Motors
    Last Post: 13-07-2020, 01:55 PM
  3. Connection hub
    By Agathon in forum General Electronics
    Last Post: 18-05-2020, 09:06 PM
  4. smoothstepper with ethernet connection
    By terry1956 in forum Motor Drivers & Controllers
    Last Post: 22-02-2016, 03:22 PM
  5. Or Guidance ;) Connection Name(s)
    By Carlb1058 in forum Marketplace Discussion
    Last Post: 13-07-2013, 12:48 AM
