    Saw that yesterday in a Facebook group. Wish it was there 8 years ago. But still, a very good option. Price is good also and its in Europe, not USA or China as usually.
    And to those that will say its not strong enough, bolt steel plates if you want something more rigid.
    I almost want to build something new with it
    https://www.vallder.com/bg/c-bg/alu-...PaWJFfcJl67n-g
Name:	gantry profile.jpg
  2. The Following 4 Users Say Thank You to Boyan Silyavski For This Useful Post:
  3. #2
    Cheers Boyan, that looks neat.
    Along the same lines as the C Beam profile you can buy from various places, have to have a closer look at that profile when I get time lol
  5. #4
    Quote Originally Posted by martin54 View Post
    the C beam is something else, for cheaper builds, does not accommodate properly square linear rails or ball screw, its more for ultra low cost builds or better suited for printers.
    Regarding bolting steel plate to aluminum profile, I thought the difference of thermal coeffecient would make it a trouble, probably not
  7. #6
    Quote Originally Posted by nhan863240 View Post
    Thermal linear expansion coefficient of Steel, ballpark 11.5 x 10-6m/(mēC). Aluminium is 22.0 x 10-6m/(mēC). The difference is therefore 0.01mm per degree, per meter of material. Lets say expected temperature variation of 30ēC maximum, on a 1 meter long gantry. Worst case, 0.3mm. Assuming M6 with a close fit clearance hole, still got another 10 degrees C before you start to stress things.
  8. The Following User Says Thank You to AndyUK For This Useful Post:
  9. #7
    Thank you! that was an "oh right!" moment for me!
  1. Aluminum plate for gantry side?
    By Black Forest in forum Gantry/Router Machines & Building
    Last Post: 14-11-2019, 06:19 AM
  2. DIY straight edge with Epoxy+ aluminum profile. Will it work?
    By ba99297 in forum Tool & Tooling Technology
    Last Post: 19-10-2019, 09:54 PM
  3. BUILD LOG: Aluminum profile and alu plate 1500mm x 600mm x 150mm working area, first cnc.
    By pierantoine in forum DIY Router Build Logs
    Last Post: 01-04-2017, 11:33 PM
  4. 600 x 400 Aluminium Profile Gantry Router
    By Journeyman in forum Gantry/Router Machines & Building
    Last Post: 02-03-2016, 04:28 PM
  5. Bridge Gantry Profile
    By ~andy in forum Gantry/Router Machines & Building
    Last Post: 16-10-2013, 09:27 PM
