13-05-2022 #21
As in the 'plug-in to the drive' side is configured as long rows......
The solder tabs on the back 'cable side' are configured as the diagram.
Just make sure you solder the numbers in the correct order.
I'd prob get a pre-made scsi cable at needed length and chop one end off. Then use a meter to mark up the pin numbers on the cut ends.
That's me being too idle to solder though!.
There are breakout /screw terminal connector pcbs you can use if you want to keep both ends of a cable intact.
Like:
https://www.aliexpress.com/item/3246...Adapt=Pc2Msite
https://czh-labs.com/products/czh-la...QaAmniEALw_wcB
Male or female depending on application.Last edited by dazp1976; 13-05-2022 at 08:11 PM.
14-05-2022 #22
Ah yes I now see what you are saying, I have a cable already I wanted to know the pin numbering from the FRONT of the cable connector. I didn't realise that they looked different from the back.
The cables I have are the 4th pic in my original post. So I wanted to cut off the NON-Servo connector (36 pin serial) and trace back the signal with a multimeter and re-use them.
Looking from the back (like you say) then it does match what I thought on the servo 1 - 18 down the left side and 19 to 38 down the right side. Which will match the from of the FRONT of the servo.
thank you very much - sorry for not clicking sooner
Every time I am wrong - the World makes a little less sense.
14-05-2022 #23-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
MSD043A1XXV Panasonic AC Servo Driver 400w - MB3 connection help
By Nemo1966 in forum Stepper & Servo MotorsReplies: 26Last Post: 22-05-2022, 05:58 PM -
By Nemo1966 in forum General DiscussionReplies: 2Last Post: 27-08-2020, 07:54 PM -
Dc servo driver
By Treemonkey in forum Motor Drivers & ControllersReplies: 11Last Post: 11-02-2013, 08:16 PM -
Panasonic 3 phase driver running on 1 phase?
By gavztheouch in forum Motor Drivers & ControllersReplies: 2Last Post: 10-05-2012, 11:21 PM -
FOR SALE: 400w panasonic ac brushless servo motors and drives
By gavztheouch in forum Items For SaleReplies: 3Last Post: 29-12-2011, 03:04 PM
