    It was a 7mm slot with semi circles at both ends, it was the same tools. I set the xyz between runs and the software is v carve pro. The material was screwde to the waste board. I will have to check if the waste board moved maybe.
    Quote Originally Posted by Andrew C View Post
    Highly likely you moved either x or y zero then.? Other less likely things could be
    #1 Cam cockup
    #2 Tool offset applied
    #3 Material moved
    #4 Tool offset applied
    #5 Lost steps
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  1. Problem using cnc3018 with offline controller
    By gikkalan in forum Chinese Machines
    Last Post: 11-07-2021, 05:33 AM
  2. NEW MEMBER: Offline CNC controller
    By IanAngus in forum New Member Introductions
    Last Post: 28-01-2020, 12:10 PM
  3. DDSCV1.1 3 and 4 axis offline motion controller
    By Boyan Silyavski in forum Chinese Stand-alone
    Last Post: 14-05-2018, 06:57 PM
  4. Offline CNC Programmer Position for Arbroath based Oil Tool Manufacturer
    By Pioneer Oil Tools Ltd in forum Opportunities Available & Sought
    Last Post: 31-07-2017, 04:22 PM
  5. RFQ: Offline Programming, Small batch Milling work, Cad design
    By lacroft1 in forum Projects, Jobs & Requests
    Last Post: 25-02-2015, 07:51 AM
