#1 Very likely be you have the wrong pull stud or the wrong holders. BT30 and ISO30 look the same but they are very slightly different.
#2 Yes you can get spring-loaded grippers which give a higher degree of flexibility but they are very expensive and difficult to find. However, if you have everything set up correctly regards locations etc then it shouldn't be needed. Alternatively, you could put the tool rack on springs so the whole rack provides some flex.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
VMC300 Toolholder question
By Proteus in forum Boxford Vertical MillsReplies: 27Last Post: 12-01-2017, 04:32 PM -
DIY Spindle Drawbar?
By Chaz in forum Spindles & Drive MotorsReplies: 4Last Post: 15-09-2016, 03:55 PM -
How to remove coventry easychange chuck/toolholder
By Rabs in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 06-11-2015, 07:08 PM -
Mach 4 Demo Released Today (Looksy only NO Motion)
By JAZZCNC in forum Artsoft Mach (3 & 4)Replies: 10Last Post: 24-04-2014, 11:34 PM -
diyCAM: Carve Released – Half off ($25) for first 50 customers!
By Chemeleon in forum Manufacturer NewsReplies: 0Last Post: 19-08-2013, 12:46 AM
