Thread: Connecting my High-Z-S 720
27-06-2022 #16
Mach3 is a bad choice, it's unsupported and does have some bugs which won't ever get fixed. UCCNC is far better software that is supported and made by the people who make the hardware, it doesn't get better than this and to top it off UCCNC is cheaper than Mach3.
Regards which controller.? I wouldn't go with USB, even the UC100 as it's much more prone to interference by electrical noise. Ethernet is the only sensible choice IMO if you are going to the trouble of wiring in a new controller.
The UC400 is ok and uses Ethernet which is far superior to USB, however, it doesn't have Analog outputs so if you want to control spindle speed through the software then you will need a separate spindle board.
The best Combo in my opinion for machines that don't require using ATC or need lots of Inputs and Outputs is the AXBB-E and UCCNC.
We fit these into all our machines and they are fantastic. Very easy to set up all in a very neat package for wiring. They provide 4-axis as standard on the board and can be upgraded to 6-axis by adding a separate breakout board which also provides extra Inputs/Outputs if required.
The UC300, UC400, and the AXBB-E all use the same Controller so in performance terms they are exactly the same. The only difference between them is the amount of I/O with the UC300 being the one that provides the most I/O for larger machines that require lots of inputs/outputs.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Connecting a VFD
By phill05 in forum General DiscussionReplies: 0Last Post: 15-04-2021, 01:02 PM -
APT High speed, high hardness end mills - anyone used them?
By Voicecoil in forum Metalwork DiscussionReplies: 16Last Post: 18-04-2020, 10:26 PM -
Laptop for connecting to CNC?
By MCmec in forum Tool & Tooling TechnologyReplies: 24Last Post: 17-01-2020, 10:26 PM -
help connecting a pot to huanyang vfd 2.2
By edgas10 in forum General ElectronicsReplies: 15Last Post: 14-08-2016, 06:45 PM -
Connecting VFD
By andrew583 in forum Spindles & Drive MotorsReplies: 0Last Post: 19-08-2014, 01:01 AM
