    Good Day All,
    Sorry If this is in thr wrong section.
    I have a home built CNC router running mach 3. Was built in 2011.
    Long story short.... Left machine running a finishing pass on some vacuum forming molds came back once finished and the spindle was sitting very randomly spinning in a none natrul way. https://youtube.com/shorts/OUIfTT_EAKI
    Parts I have changed thus far....
    A new pmdx 126 and 107 board have been fitted.
    If any one can shed any light onto this i will be greatful as you all know, Its an expesive table if its not cutting.
    Thank you in advance
    regards Tom
    Have you checked for a broken connection at the spindle or somewhere along the cable where it gets a lot of flex
    If i had enabled the spindle and it was doing that i would understand wiring but thats only just enabling Mach 3 before its referenced,
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    What actually switches on/tells the VFD to power the spindle?
    BOB output? via a relay? MODbus? ??
    I have a PMDX 126 (BOB) then a PMDX 107 options card that controls the VFD
  1. Import vat issue!
    By marbles in forum Marketplace Discussion
    Last Post: 13-11-2018, 04:00 PM
  2. Arc movement issue
    By lukecnc2012 in forum Metalwork Discussion
    Last Post: 09-08-2015, 07:15 PM
  3. Porter Cable 22-7519-60 Router Motor Issue
    By kully in forum Porter Cable Routers
    Last Post: 12-05-2015, 01:07 PM
  4. THC Setting Issue?
    Last Post: 17-10-2014, 07:53 AM
  5. Spartan Router - Head drop issue
    By Abstract in forum Gantry/Router Machines & Building
    Last Post: 29-09-2014, 02:08 PM
