Ok i have the predecessor to this (5 axis controller). At best i would not recommend this to run over 24v even with the new chips. There is not enough protecttuion in the circuits for these units. To fix the problem you will need to replace the main ic's. check wit the specs,
24-12-2009 #2
Anything over 24V DC then you are risking popping the driver chips.
This can be caused by bemf and AC line voltage fluctuation or a combination of both.Visit Us: www.automationshop.co.uk
WANTED: Tb6560ahq ic
By Philly in forum Items WantedReplies: 20Last Post: 20-10-2012, 08:12 PM -
TOSHIBA THB6064AH Updated Active IC
By lihaijiang in forum Manufacturer NewsReplies: 1Last Post: 09-04-2012, 03:43 AM -
WANTED: Anyone got a TB6560AHQ IC?
By HankMcSpank in forum Items WantedReplies: 3Last Post: 14-02-2012, 11:13 PM -
Heads up, ebay
By Robin Hewitt in forum Computer SoftwareReplies: 4Last Post: 22-08-2010, 06:13 PM -
NEW MEMBER: new to cnc having problems with toshiba tb6560ahq
By elecom in forum New Member IntroductionsReplies: 19Last Post: 25-11-2009, 11:15 AM
