10-06-2014 #21
looking at zapps site I cant see any kits of parts but if i put together
4 dm856 drivers 4 nema 23 3 nm motors and one plc6x BOB and a 68v 6amp power supply
its £632 ish
Cnc4you's kit of parts is 356 plus vat 427 ish thats this kit ...Nema23 Stepper Motor Kit 4Nm x 4 Axis
will I notice any major difference with either of those over my cheapy ebay special ?
10-06-2014 #22
Cnc4you is the best place to buy the steppers 3.1nm low inductance that I know of. But not the drivers Ebay is your friend for them like this one :- Leadshine AM882 Digital Stepper Motor Drive 80VDC 0 1A 8 2A Protect Function | eBay although I think there is a newer model you might find a better price as well. ..Clive
10-06-2014 #23
Don't go with the kits has they tend to be under spec'd on the PSU or have lower spec drives etc. You don't really save anything buying kits anyway if you shop around and to be honest if you build your own PSU you'll save more money.
Ian Check your PM's.
17-12-2014 #24
05-05-2015 #25
Thank you very much for a very informative explanation on motor selection.
I'm upgrading an older machine that had two motors driving X axis gantry. How do I calculate the motor size with two motors on the same axis? Is it a simple as dividing by 2?
Gecko recommends a 40% increase in motor size from base calculations, do you agree?
Thanks again
Mike
07-05-2015 #26
Not so simple. First you need to know the moving mass. Then the desired speed and acceleration. Then you decide the motors and the ratios. Then you check if your BOB can cope with that. Then you check what your resolution will be. Some back and forth between all that and a final decision. At least that's my logic.
07-05-2015 #27Do you mean the drivers?.Then you check if your BOB can cope with that.
Mike But as Silyavaki has said there is more to it. How about posting some pics of the machine for a better answer. ..Clive
07-05-2015 #28
I did the calculation, 670 oz-in/4.6 NM is required to move the axis with one motor. I would normally add +30% for efficiency loss and use a motor in the 850/6 range. With all that, I have a pair of NEMA 34 frame motors that are 420/3. Will I be ok with these or should I go with something bigger? I'm sure that a frame size increase to 34 will slow down my Rapids.
My drives are Gecko 203V, I have several power supplies ranging from 36 to 70 volts available. I upgraded to a Ethernet Smooth Stepper with a high end BOB so I should be able to handle most anything.
Thanks again for your help.
Mike
07-05-2015 #29
Well are you using ball screws, pitch, size, direct drive, etc etc. Without full info nobody will be able to answer you. I take it you don't want to post any pics . Generally nema 23 are more than enough running at about 70V. ..Clive
07-05-2015 #30
Ball Screws, direct drive, .5"/rev, 48"X48" table, 2.2 KW water cooled spindle with 10" of travel. The machine is totally in pieces but I will post pictures as it goes back together. I'm replacing the rails and bearings so most of the machine is in tote boxes or stacked in a corner.
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM -
Motor size
By Philmollatt in forum Motor Drivers & ControllersReplies: 8Last Post: 15-10-2009, 08:39 PM -
What stepper motor size (torque)
By ZeroCount in forum Stepper & Servo MotorsReplies: 5Last Post: 09-02-2009, 11:54 PM
