07-05-2015 #30
Ok then I take it you have read this earlier in this post from Jazzcnc
It might be better to keep away from direct drive and use belts and pulleys with a 2:1 reduction (that's what we tend to do this side of the pond) ..CliveI'll save you a lot of headache and just say use 3Nm motors run at 65-70Vdc on 75-80vdc drives and you won't have any problems cutting anything.
Cutting speeds will depend on many factors like spindle power and tool material but 4500-5000mm/min wouldn't be out the way with 2.2Kw spindle using carbide tooling.
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM -
Motor size
By Philmollatt in forum Motor Drivers & ControllersReplies: 8Last Post: 15-10-2009, 08:39 PM -
What stepper motor size (torque)
By ZeroCount in forum Stepper & Servo MotorsReplies: 5Last Post: 09-02-2009, 11:54 PM
