I think its a fact that microstepping, where you are actually stopping at the microsteps (i.e. using them for resolution) definitely is less torque, simply because the motor cannot hold that position accurately against load. In a dynamic situation however, lots of factors come into play. For example, if the axis is in constant motion the only torque required is to overcome friction and cutting loads, there is little torque required to provide acceleration. Unless the motor is being operated close to its torque limit (at that speed/volt/current combo) then microstepping should have little impact. The general rule I have used is in the spreadsheet is that the motor should provide 3x required dynamic torque at the maximum speed.
Large motors have high inductance so the torque drops off very fast with speed - the corner speed of those motors is 240rpm. I don't know how big your axis are, but I'm guessing its going to be around 1 - 1.2m? With your 10mm pitch screws 2.5m/min = 250rpm, so that is close to optimal (and 1/8 stepping = 6664steps/sec) and it looks OK at cutting speeds, but its very marginal at 10m/min rapids and that is where you may have lost steps (=27000steps/sec). You need to reduce rapids to 7m/min but it should be OK at 1/4 or 1/8 stepping.
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM -
Motor size
By Philmollatt in forum Motor Drivers & ControllersReplies: 8Last Post: 15-10-2009, 08:39 PM -
What stepper motor size (torque)
By ZeroCount in forum Stepper & Servo MotorsReplies: 5Last Post: 09-02-2009, 11:54 PM
