    Lives in Plymouth, United Kingdom. Last Activity: 19 Hours Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    I'm trying to use the spreadsheet to check some parameters of my planned new router. This has thrown up a few questions:
    1. Acceleration seems to be the largest contribution to torque required, but I can't find where load acceleration is built in. It must be in one of the formulae somewhere but I can't manage to unpick the formulae in the hidden columns to find it.
    2. The spreadsheet recommends a motor torque based on an assumed safety margin of 3; if the safety margin isn't high enough with my intended motor, I presume that I could restrict the machine to a lower acceleration? But given that I don't know what acceleration is assumed, it's difficult to see what's happening. I do see that the acceleration torque number is linked to cutting speed.
    3. For a twin ballscrew X axis, I assume that I can use the spreadsheet using actual ballscrew dimensions (single ballscrew) to give critical speed, but then use a double-length ballscrew in the spreadsheet to do the torque, etc, calculation.
    4. If I go to a twin-motor setup, can I simply double the nominal motor torque? Or is it easier to halve the gantry mass and do the sums for a single motor/ballscrew?
    To put some reality into this exercise, what would be sensible numbers to use for cutting speeds and accelerations? Bit of a "how long's a piece of string?" question, but my current router is so far out of the norm I don't feel that I can extrapolate from what I'm doing at the moment, and I don't know what kinds of numbers are reasonable. For starters, I would assume profile cutting, say, 9mm ply with a 6mm cutter in a couple of passes. Currently, with speed limited by machine rigidity, I would cut that at maybe 600mm/min.
    Many thanks for any help available!
    I'll save you a lot of headache and just say use 3Nm motors run at 65-70Vdc on 75-80vdc drives and you won't have any problems cutting anything.
    Cutting speeds will depend on many factors like spindle power and tool material but 4500-5000mm/min wouldn't be out the way with 2.2Kw spindle using carbide tooling.
  3. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
    Can you suggest a supplier of a kit of parts to do as you have described Jazz? for a 4 axis machine?
  1. Replies: 1
  2. Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
    By LoveLearn in forum Gantry/Router Machines & Building
    Last Post: 08-02-2012, 01:52 AM
  3. Stepper shaft size and pulley bore size problem
  4. Motor size
    By Philmollatt in forum Motor Drivers & Controllers
    Last Post: 15-10-2009, 08:39 PM
  5. What stepper motor size (torque)
    By ZeroCount in forum Stepper & Servo Motors
    Last Post: 09-02-2009, 11:54 PM
