06-07-2022 #1
Hi All,
First of all apologies if this is in the wrong place. I am looking for my first CNC for engraving watch dials and various other small tasks.
I have no idea where to start. Im not sure whether I need a proper CNC Mill, a Gantry Router etc etc.
What I need to be able to do primarily is to engrave non ferrous metals - for example engrave guilloche patterns or numerals and other markings onto sterling silver discs. The disc may be 30-37mm diameter, 0.4-0.6mm thick. The markings can be as small as 0.1mm line width with an equivalent depth of cut. SO very small details, relatively accurately. I currently use photo etching to do this, but it seriously limits my design and the materials I can use. I have seen videos of the Nomad 3 doing this very well.
A second use which would be really lovely to be able to do would be to make various watch parts. Eg a watch case out of argentium silver, or a movement bridge out of brass. If I could very occasionally cut some sort of free machining stainless steel (or other ferrous metals) that would be amazing (but im guessing unlikely). I know whatever machine I end up with will not be able to achieve the accuracy I need for bridges, but I intend to finish the parts using alternative methods after the rough cutting has been done.
I can't imaging I will need to machine anything larger that say 60x60x20mm, so we are talking quite small parts.
I have been researching this for months and still don't know where to turn. Im guessing a traditional metal mill style machine would be the ideal but im guessing also out of my limited budget? If not then where to look? Could I do this on a gantry style machine? will it give the accuracy? Any advice is needed.
The research I have done suggests the Nomad 3 is the best option. At around £3k it is right at the top of my budget and this makes me nervous. I would also prefer to buy from British company if possible. I have no problem with building or setting up a simple kit, but don't think I would be able to covert a manual mill (too much of a learning curve with limited time)
Im sorry about the lengthy post but wanted to give you as much info as possible.
Needed some advice, please.
By PLIP5 in forum General DiscussionReplies: 3Last Post: 29-07-2018, 07:45 PM -
Advice needed on everything
By chrisjames in forum General DiscussionReplies: 12Last Post: 11-11-2015, 11:40 PM -
Quick Advice Needed - F&S
By Tenson in forum Tool & Tooling TechnologyReplies: 1Last Post: 01-01-2013, 06:38 PM -
First steps, advice needed
By Wobblycogs in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 02-11-2012, 02:30 PM -
SPG X3 CNC Mill, advice needed please
By shaggyhawkings in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 07-01-2010, 11:00 PM
