Hello!
I would like to get some inputs on a machine optimized for 3d wood carvings I am potentially planning to build.
Working dimensions would be 1500 x 1000 x 150 mm using rotating ball screw. Screw would be 1616 or 2020 for X and Y, and 1610 or even 1616 for Z to get faster Z traveling speeds. Rapids are not important that much. I would use mains powered Lichuan steppers.
It would use small diameter end mills, I was thinking about 40 000 rpm spindle with ISO20 er16 (1-10mm clamping range) or er11 tool holders (1-7mm) since I mostly use 6mm end mill for rough passes. 1.5-2.2 kW should be enough for these purposes.
something like this:
https://www.jian-ken.com/automatic-p...-40000rpm.html
I would be doing really detailed carvings using 0.5mm, 0.75mm, 1mm diameter tapered ball nose end mills.
Because of small tooling, the gantry also could be lighter.
I would like to have ATC, but since these jobs usually take a long time, maybe it's a waste.
Do you have any suggestions on what could be optimized for faster carvings?
Thanks in advance.
New CNC wood lathe machine
By Therese Lam in forum Machine DiscussionReplies: 5Last Post: 16-09-2018, 08:32 PM -
Which Machine? 8'x4' for routing wood.
By warrenfalzon in forum General DiscussionReplies: 0Last Post: 08-04-2018, 10:25 PM -
machine for wood only
By feetsy in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 28-04-2015, 07:59 PM -
tools for 3d wood carving
By chris in forum Marketplace DiscussionReplies: 5Last Post: 18-01-2014, 04:23 AM -
RFQ: Midlands based, wood carving prototype required (A3 size)
By lee.hatton in forum Projects, Jobs & RequestsReplies: 0Last Post: 06-01-2014, 06:05 PM
