21-07-2022 #11
I'll send some photos in my next reply as I am away from it at the moment.
I worked through the issue with SIEG and checked that there were no conflicts with other applications occupying UDP ports as as firewall issues between the PC and the lathe. (PC and Lathe are connected over a Ethernet connection.)
As directed by SIEG:
Checked the voltage from the switching PSU used by the ATC
Increased the current from the Stepper-Motor Driver (number turns suggested by SIEG)
Then replaced the switch PSU used by the ATC and verified the voltage was in the correct range
I spoke to another engineer in the UK that has some experience with the iKC4 and he suggested updating the firmware version as this has resolved these issues in the past. Unfortunately this did not work. He then suggested a visual inspection of the motion controller board to see if there were any obviously blown ICs. There are none.
I will reply with some details regards stepper motor drivers, etc. shortly.
Sieg mini lathe cnc conversion need help
By diddly in forum Sieg LathesReplies: 0Last Post: 20-12-2014, 10:53 AM -
Chester MF42B Lathe Wiring Issues
By kingcreaky in forum General ElectronicsReplies: 5Last Post: 18-02-2013, 02:21 PM -
FOR SALE: Sieg C3 Mini Lathe
By Jonathan in forum Items For SaleReplies: 1Last Post: 07-05-2011, 06:19 PM -
WANTED: SIEG C3 Mini Lathe
By derekm in forum Items WantedReplies: 5Last Post: 07-04-2010, 08:35 PM -
WANTED: SIEG C3 Mini Lathe WANTED
By derekm in forum Items WantedReplies: 0Last Post: 03-08-2009, 03:02 PM
