  1. Right, I've just tried this. Look at the Feedrate DRO just above the MDI. If M3 has just been started it probably says 5 mm/min. So if you type in Z-5 it crawls along. To be frank I've never not typed in a G-code word into the DRO so never seen this behaviour, I would always specify a feedrate. If you type Z-5 F100 it moves MUCH quicker and the default feedrate is now set to 100mm/min until you use another F word to define a new one. Doddy is quite correct.
  2. The Following User Says Thank You to JohnHaine For This Useful Post:
  1. Harrison Alpha 330 lathe Fanuc 21it SRAM back up problems
    By Sucram in forum General Discussion
    Last Post: 24-02-2021, 03:44 PM
  2. Replies: 0
    Last Post: 15-12-2019, 09:44 PM
  3. Mach3 Problems problems problems.
    By ECCO in forum Artsoft Mach (3 & 4)
    Last Post: 09-07-2016, 10:07 AM
  4. CNC style lathe home brew Lathe for drilling and cutting.
    By Bodge in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 18-04-2012, 10:45 AM
  5. Help please with warco 220 lathe motor problems
    By wiggy in forum Milling Machines, Builds & Conversions
    Last Post: 07-09-2010, 10:14 PM
